morgnstern's avatar
morgnstern
Parental controls for individual devices only works on IOS
Parental controls are working when set as a default policy and I am able to change the policies to recieve different results. I would like to set my default policy as restrictive and manage specific devices for less restrictive policies. I can seem to be able to control IOS devices specifically. I cannot control Windows 10 or Android devices. It doesn't matter if they are configured for DHCP or static addresses. I have tried from multiple devices and have had no luck. It seems like both Windows 10 and later versions of Andriod will not accept policy based filtering. Is this a known bug or is there a KB article on how to fix this? I also cannot log into my openDNS account from the netgear genie app through parental controls but it works fine on IOS and PC. I have tried resetting the router, disabling parental controls, access control, etc., etc.. Any help is much appreciated.
-Chris
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi morgnstern,
    1. Are you using the per device filtering describe in the KB article linked below?
    http://kb.netgear.com/app/answers/detail/a_id/29913
    2. On which device/s are you not able to login to your OpenDNS account through the app/program?
    3. What version of the app/program do you have installed?
    4. What is the firmware version of the router?
    Dexter
    Community Team
    • morgnstern's avatar
      morgnstern
      Dexter,
      1. Yes
      2. My Android (Samsung S7) Android version 6.0.1, App version 2.4.38
      3. R8000, Firmware version V1.0.3.4
      From my phone, via the network map, I cannot change my filtering level by device. The option is no longer there. When it was, it didn't let me, I just got an error "failed to set parental controls". Other devices it would, such as my Ipad. Also from the phone, when I go to parental controls, it prompts me to log in to the router, then it prompts me to log into OpenDNS, and I cannot get past that login prompt. From my PC I can, on my ipad I can.  From my Ipad I can change the filtering level of my ipad, but not my phone. From my Ipad, I can logon to my bypass account, from my PC I cannot. My phone doesn't get far enough into parental controls to even have the option.
      On a side note, I noticed I can set filtering at the "Opendns.com" Cisco Umbrella site by managing my personal network and I can also set it at netgear.opendns.com. It seems like the Cisco Umbrella site takes presidence. Should one be used and not the other?
      Thank you for looking into this.
      Chris
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi morgnstern,
        Thank you for providing the details.
        We recommend using the filtering settings set via the NETGEAR Genie app/program which is in sync with the one in netgear.opendns.com. Your settings via the Cisco site may be conflicting/affecting how the NETGEAR filter functions.
        Dexter
        Community Team
