Dragonlim
Jul 06, 2017Guide
R6120 Security Menu Missing Access Control
Just bought R6120 yesterday. Want to setup MAC Access Control List, unfortunately cannot find it in Security Menu.
Hope that it will be available in the next upgrade.
Fya, Thanks !
Fya, Thanks !
Hi All,
I just upgrade to the new firmware V1.0.0.28.
Good News !
Access Control is available and working fine !
Hope that it helps other with the same issue.
Thanks.
Best regards
Dragon Lim
Does that mean that page 39 of the manual is misleading?
R6120 | Product | Support | NETGEAR
"You can use access control to block or allow access of devices to your network. You define access by selecting or specifying the MAC addresses of the wired and WiFi devices that either can access your entire network or are blocked from accessing your entire network."
Or are you trying to do something else?
- dandymikeAspirant
michaelkenward wrote:Does that mean that page 39 of the manual is misleading?
Yeah the manual is misleading, the option ADVANCED > Security > Access Control. isn't there!!! I have checked the product page and i am currently on the most recent available firmware v1.0.0.16
I have seen reports of new firmware depriving people access to some functions.
It is a complicated saga. Sometimes it is down to region settings, but that seems to be for wifi.
Yes, it is misleading. Access Control is not available at all ie. have gone through all the menu items available.
Please advise when the next upgrade will be available to turn on this feature.
I use Fiddler to capture the traffic, I manage to get the link to Access Control. But, even I get there, the
Access Control Page is available, but nothing can be done. Fyi.
Thanks.
Dragonlim wrote:Please advise when the next upgrade will be available to turn on this feature.
You'll have to ask the official support people.
