r7000_nooby
Jun 14, 2018Aspirant
R7000 Nighthawk Readycloud setup won’t allow read/write.
Windows 10/Windows 7/Linux, home network only, with latest firmware as of 06/13/2018
I have set up Readycloud, have a ReadyCloud account, and am able to login in to it from a browser.
After login all I see are the symbols for the R7000 router and the share name.
But selecting the share name, it doesn’t present me with the folders/files that are on the shared drive.
If mapped as a network drive in Windows, no problem reading/writing to the share drive.
I have done everything that the dashboard asked of me to set it up and get an account.
So, what am I doing wrong that ReadyCloud won’t allow me access to what I know is there?
What firmware version do you have on the device? A number is more useful than "the latest". (It may not be by the time people read this.)
There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.- r7000_noobyAspirant
FIRMWARE VERSION
V1.0.9.32_10.2.34
Good enough?
Installed the the day I updated to the ‘latest’ firmware!And made the OP to this thread on 06/13/2018 IIRC.
and IMO, if there are ‘hotfixes’ then Netgear should be informing us.... just saying
And firmware should not be a condition of how ReadyCloud works. Again IMO.
I have been trying to get that thing to show my files/folders for over a year! And all I get are those icon symbols that go nowhere and do nothing.
r7000_nooby wrote:
and IMO, if there are ‘hotfixes’ then Netgear should be informing us.... just sayingHotfixes are "work in progress". Ready for people to use, but not tested enough to release them into the update process.
If don't want to look for them, just wait until they arrive in the official channels.
Firmware is the software, in effect the "operating system", that makes your hardware work. Of course it affects how ReadyCLOUD operates. No firmware = no ReadyCLOUD. Broken firmware = broken ReadyCLOUD
I have been trying to get that thing to show my files/folders for over a year! And all I get are those icon symbols that go nowhere and do nothing.What are these "icon symbols? I suspect a configuration issue at your end.
ReadyCLOUD isn't the easiest thing to set up. It requires various steps. It is hard to diagnose where things may have give wrong with so little to go on.
I assume that you have your router registered in the router.
Have you installed the ReadyCLOUD software?
Did you factory reset the thing after the latest firmware update?
