Tech16
Mar 27, 2017Initiate
R8000 Firmware Update R8000-V1.0.3.36_1.1.25 breaks Live Parental Controls and Genie App functions
Updating firmware on R8000 to R8000-V1.0.3.36_1.1.25.chk (latest recommended update) breaks Live Parental Controls (LPC)-cannot turn ON or OFF from web app (Gui takes you instead to NetGear page, http://www.netgear.com/lpc?cid=wmt_netgear_organic). Genie Mobile App does not allow you to login to LPC to turn LPC ON or OFF. Update also breaks Genie Mobile App "Network Map" feature which now only shows router and device running Genie App-no other devices.
Rolling R8000 firmware back to R8000-V1.0.3.32_1.1.21.chk restores functionality to both.
Please fix ASAP because with R8000-V1.0.3.32_1.1.21.chk, my internet connection goes UP and DOWN constantly which appeared to be fixed in R8000-V1.0.3.36_1.1.25.chk.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So a factory reset is the first thing to try if you have problems with new firmware.
- lbotezTutor
I've reset to factory settings several times. It still doesn't allow me to get into the router via software.
Seems the Genie software might be broken. For mac and pc. Plus I can't seem to be able to downgrade to the previous software.
lbotez wrote:I've reset to factory settings several times. It still doesn't allow me to get into the router via software.
The first message was about Live Parental Controls, a broken network map and a dodgy Internet connection. I suspect that these are not the same issues as not getting into the router "via software". It is more likely that the inability to get into the router is the root cause of all these symptoms.
What happens if you try the web browser rather than the apps?
The "can't get into the router" thing is a perennial. (Just browse around here a bit.) There are various possible reasons.
For example, the R8000 is a router. This means that there is probably a modem in there somewhere. That can lead to conflicts between the two and which gets to hand out IP addresses.
Using the browser to troubleshoot is usually easier than messing around with the standalone genies.
Here is just one item in the KnowledgeBase:
If you cannot login to your router | Answer | NETGEAR Support
- Tech16Initiate
Hi michaelkenward,
Reluctantly, I followed your suggestion. Updated to R8000-V1.0.3.36_1.1.25 firmware and reset unit to factory settings (holding reset button for 10sec). Then manually re-entered all my previous settings including DDNS, reserved IPs, port mappings in addition to all the Wifi settings.
Same result. No access to Live Parental Controls (through web and ios Genie app) and no devices other than ios device running Genie app showing up on Genie Network Map.
Since I need to have LPC working this evening, I restored firmware back to R8000-V1.0.3.32_1.1.21 and all is working again! I really believe there's something broken with R8000-V1.0.3.36_1.1.25 firmware.
- lowmanAspirant
I Just updated firm ware in the R8000 I now can not connect with the Genie .. Log in says some thing about ipv6 and it stops there . I updated the Genie app same results . Not happy with this 300 dollar brick since day one .
First, did you factory reset the router? That is the first thing to try of you have post-flash problems.
Second, can you get into the web interface using a browser?
PS You have joined in on an older discussion about a different subject so there's a chance that the official support team will be too busy following new stuff to find your message. It is usually better to start your own fresh discussion if you want their attention.
- lowmanAspirant
Did not try factory reset . The Genie will not recognise the router even after updateing to new version . I tryed disableing the IPv6 and it will default to another setting instead of disabled . Current verson firm ware after flash 1.0.3.36-1.1.25 . For some reason my Go Flex nas is not scessable thru and ftp that is on put
Ipads . The nas was giving issues before the flash and reason for flash was the usb ready share was malfunctioning the ready share was found to be a bad usb extension cable between router and storage it seems that that issue is resolved . I can acess nas thry seagate dashdoard but not the ftp on any Ipad . I can not even log in with Ipad genie it tosses the Ipv 6 thing . I am lost when it rains it pours . What version firmware should I roll router back to .
- AlexKNYAspirantI have the same problem after update !
- CdricAspirantSame problem here also after update! Don't propose me a useless factory reset but please give us the solution that's really work or give us a new firmware update that solve this problem. Thank you.
