McPoop's avatar
McPoop
Strict NAT on PC-NightHawk R7000
A friend and I play Destiny 2 on PC. Getting a Strict NAT recent so tried checking genie app. Won't let me sign in on my PC but will on my phone. The phone app doesn't have access to 'Router Settings'. When I try signing in via PC it says, "NetGEAR router is not found or is not supported. Also, make sure the device is not connected to the guest network of the router, and no IPv6 is enabled".
OS - Windows 10
firmware - v1.0.7.2
Thanks for any and all future advice!
McPoop
  • Hi McPoop,
    1. Please try using the router's IP address (default is 192.168.1.1) and see if that works.
    2. Please try using another device (another PC, mobile) via a browser.
    3. You should be able to to get to the router's UI whether the device is wired or wireless.
    4. Once you have access to the router's UI, you may want to look into port forwarding for the issue you are facing with the game. Additional info from the game developers (port numbers, protocols) maybe needed. The link below may help out.
    https://kb.netgear.com/24289/
    Dexter
    Community Team
    • McPoop's avatar
      McPoop
      Hello DexterJB
      1. I am connected via ethernet cable.
      2. When I try to sign in through either of those links, this is a snip of what I get.
      3. I've read somewhere that sometimes when multiple people play the same game in the same room, they may think you are hacking and strict your connection or kick you all together.
      4. Regarding the pic, I do not have a wireless card on my pc so cannot connect that way. Could that be a problem?
      Thanks,
      McPoop
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi McPoop,
      Dexter
      Community Team
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi McPoop,
        I would like to follow up and check if you are still experiencing the issue.
        Dexter
        Community Team
