GrimOne
Oct 19, 2025Follower
Stuck in a dilemma in regards to Nighthawk configuration and management
After almost five decades of working in the comp tech industry I developed an eye condition limiting my ability to utilize technology. In particular, mobile tech. Besiides the fact that I have worked...
CrimpOn
Oct 19, 2025Guru - Experienced User
When Netgear decided to remove Remote Management from WiFi routers in favor of the smartphone app, they did not remove OpenVPN access.
If OpenVPN server is enabled on the Nighthawk router, that makes it possible to use an OpenVPN client on a computer to gain remote access to the Nighthawk LAN. Being on the LAN enabled aess to the Nighthawk web management. I have used OpenVPN Client on smartphone, tablet, Windows Laptop, Linux laptop to access my Netgear WiFi router remotely.
