craholtz
May 28, 2020Aspirant
Compatibility with AT&T UVerse
Is Nighthawk Dual Band Mesh WiFi 6 System - 2 pack (MK62) compatible with AT&T
Yes.
do you usually have to make changes with the att device to get it working properly? Yes. ATT tends to give people combo units which makes the network run a double nat without some changes to either the att router or the netgear router.
- craholtzAspirantCurrently I don’t have a router, just a modem. I’m getting about 40-50 mbps download speed, which is the fastest speed available for my area. I was told that this router would help with all of the WiFi devices running in the house which is about 3,000 sq ft and is two-stories. I just want to make sure it will work with our AT&T U-Verse.
again, most of att devices have an integrated router. Which device are you currently using?
