novermyhead's avatar
novermyhead
How do i Create a Mesh system with a Nighthawk X 10?
I am currently using a Nighthawk X10 r9000 Router and while i am please with its performace,I am finding a few dead zones in my house. I have looked at the Orbi system but I dont really want to puirchase  whole new system. Can i add the nighthawk Mesh system to my current setup?
Thanks in advance
  • plemans's avatar
    You can add a mesh extender to your network. They work amazing if you're only adding 1.   When/if you start needing more than 1 extender, thats when you should be looking into the true mesh setup instead of just a mesh extender.
    How big is your home?
    What are the interior walls made of?
    • novermyhead's avatar
      novermyhead
      My home is around 2500 Square feet. Most all place are covered exepct my bedroom. The wall are typical 2x4 with 3/4 in sheet rock. Would i need to purchase just one of the Orbi,or should i go with the Nigt Hawk Mesh system?
      • plemans's avatar
        Your home should probably be fine with single extender. But thats a "probably" because many things can influence wireless coverage.
        Quite a few stores have generous return policies so if you bought a mesh extender and tried it and it didn't provide the coverage you desire, you could return and switch to mesh.
        The x10 is quite capable as a router. I'd probably start with adding the tri-band mesh extender and seeing how it performs.
