dondale's avatar
dondale
MK62 adding more satellites?
Hello,
Is it possible to add additional satellites to the MK62 Nighthawk Mesh system? I've looked around, and it doesn't appear that the satellite is sold separately. Is it possible to configure the router itself as a satellite -- so if I want a router and 3 satellites I can buy two of the MK62 system? Are there other devices that would function as a satellite due to the EasyMesh standard?
Thanks so much for your time and attention.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello dondale,
    You certainly can! One router will need to be in wireless access point mode. However, the request for an additional satellite to be available for purchase is a request our product teams have considered. At this moment we do not have any further details on if/when a separate satellite would be available.
    Stay tuned!
    Christian
    • dondale's avatar
      dondale
      Thanks so much, Christian! As a followup question: Is it possible to connect all three satellites to the router via Ethernet, through a switch?
      Thanks again for your time and attention.
        Christian_R
        Happy to help, dondale! And yes, both should work.
        Christian
    • iamck's avatar
      iamck
      Guide
      Hey
      I’m trying to do the exact same thing? Has anyone instructions on how to do this? I can’t figure it out at all?
      I have it connected over cable to the original router (as it fails the add satellite sync thing) so I can get it an ip 10.0.0.28 but I can’t log into it to set it as an access point which I assume is what I need to do?
      I finally got the second satellite working after 30 tries but just need the router as the third!
      Any help very much appreciated.
      • Chrismerch's avatar
        Chrismerch
        Initiate
        Access point is not the same, it doesn’t join the mesh network and I am forced to change the WiFi name. This needs to be fixed, how is it possible that this isn’t supported. It’s such a basic concept and it can rectified with an update. The MR60 should have Router Mode and Satellite mode. Can someone offer insight if there will be new firmware that can resolve this? It’s almost $500 worth of hardware that I’ll be forced to return to the store in exchange for something that doesn’t restrict this such as Eeros. It’s clear that I’m not the only person with this issue :(
  • Hello
    I have just bought a Netgear Nighthawk MK62 mesh satellite system and I’m really pleased with it - works a treat.
    I know you’ve said here that there are no plans at the moment to offer separate satellites for sale, so if I bought another system with router and two satellites, could I use that as three satellites i.e. one router and five satellites in total?
    Thanks
    Gary
  • I did exactly the same as many others, purchased two sets thinking the additional router could be configured to work on the mesh network, as another satellite and not as an Access Point. I'm so annoyed that it can't function as another Satellite.
    I can only think that NETGEAR are trying to pull a fast one to bring in the $... I mean directing consumers who need more units to buy them individually at ‘huh – why would I pay that for one?’ nonsense prices! I guess I should have checked the forums etc. first! But a bizarre strategy and pricing structure regardless. I’ve a feeling we'll be seeing a few brand new, redundant routers on ebay very soon... netgear please have rethink, preferably with your customer experience hats on ! Thank you…
