shixinhb's avatar
shixinhb
Follower
May 04, 2022
MK63 DHCP not working
Hey,
I have my mk63 connected to a Arris SB6141 modern with Xfinity. The DHCP is turned on on my mk60 main router. I have several devices that cannot automatically get a valid IP address from the router like my PC and my XBox series X console, sometimes my Apple TV box.
I have to manually assign IP to them. It works but really annoying when network not stable, while troubleshooting I have to check if this device is use manual IP or rely on DCHP.
I have no clue why it is not working against some of my devices. PC is connected to the main router with a cable. Xbox is connected to the satellite with a cable. Apple TV via WiFi.
Let me know if any other info you need from my end.
Any guidance will be greatly appreciated! Thanks!
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Is Armor or Smart Parental Controls enabled?
    Try setting a IP address reservation on the MR for your devices:
    https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router?_ga=2.258726095.431341290.1651496399-938141478.1647526868
  • I'd look in the log (Advanced tab, Administration on left, Log below that) on the router when you connect a new device to see what it thinks happened.  Each of my devices gets a new line when they take an address.
    Plugging a wired device into the router is the simplest way to test if IP addresses are being given out by the router.  Skips any WiFi issues (try that next when IP's are handed out reliably).  You can manually release then renew the address to trigger the process quickly (search online for directions for your OS).
    You could do a factory reset to make sure you didn't accidentally turn on a feature you didn't remember.  Like routers can require you to whitelist MAC addresses ("default deny access").  That's different from reserving an IP for the device on the router (which still uses a DHCP server).
    When you say you manually assign an IP, you're setting a static address on your devices?  It generally works best to have everything static or everything use DHCP.  Like to avoid multiple devices thinking they can use an IP (one forced with a static address and the other handed the value from DHCP server).
    You can try upgrading the firmware, though some people have better luck on the last 1.0.x version (current is 1.1.x).
