russellwhite
Mar 30, 2023Tutor
MK63S not showing devices
I have an MK63S with two satellites. When I look for connected devices either on the Nighthawk app or via a web browser, none of the connected devices show up. They are all on firmware version 1.1.7.134
- It could be with it being a new system that it upgraded several versions of firmware. Sometimes updates are helpful with a factory reset. Might be worth trying.
- plemansGuru - Experienced UserWhat modem/gateway is the router connected to? Are you using a switch for the satellites or are they wireless? Did you try a reboot or factory reset? - Connected to a Netgear cable modem CM1150V No switch, the satellites are wireless (is a Mesh wifi system). I have not tried a factory reset because I just set them up yesterday.
 russellwhite wrote:
 none of the connected devices show up. Showing up where: - Mobile app?
- Browser graphical user interface (GUI)?
 This is a good alternative for Windows and Macs: genie | Product | Support | NETGEAR Be warned that the genie installation file is wrapped up in a RAR archive that you have to decompress and install. Netgear is trying to kill this useful utility. - That was in the original message. Both the app and the browser show 0 connected devices. - plemansGuru - Experienced UserIt could be with it being a new system that it upgraded several versions of firmware. Sometimes updates are helpful with a factory reset. Might be worth trying.
