uhcax30's avatar
uhcax30
MR60 Guest Network isolation
I have MR60 and two satellites connected to a CAX30. The MR60 acts as a Router.  I am not able to isolate Guest network from internal network. I do not see any option to block guest network from seeing internal network.
  • I'll see if I can find out if this is expected behavior. As long as you can't access those device, should ok.
  • FURRYe38's avatar
    How are you determining this?
    What FW version is loaded on the MK60 system?
    • uhcax30's avatar
      uhcax30
      I am able to scan the network and see every device on the network.
      I am running the latest version of firmware on both MR60 and MS60s.
      • FURRYe38's avatar
        Can you access any of the devices from the guest side?
        I saw my Wired Windows 10 PC on my Mac Book that was connected on the GN. However I could not access it's shared folders. When i changed the Mac Book to the main wifi network, I could then access the shared folders.
