santeeslim's avatar
May 05, 2022
MR60 intermittent failures
I've been having intermittent failures with my new router as show in the following log file. Is this normal? If not, what can I do to correct it.?
Wait for Ping (milliseconds): 200
Test Interval (seconds): 5
Log Failure Longer Than (seconds): 5
Failure Start Length
---------- Note ----------
4/30/2022 1:02:11 PM
Changed Settings...
Log Failure Longer Than (seconds): 2
------ End of Note -------
5/1/2022 1:11:51 PM 0:00:18
LAN Failed - No router response
5/1/2022 6:27:52 PM 0:00:04
LAN OK - 192.168.1.1 responded in 0 ms
5/2/2022 6:13:20 PM 0:00:06
5/3/2022 6:12:56 PM 0:00:08
5/4/2022 10:34:17 AM 0:00:03
5/4/2022 6:13:38 PM 0:00:03
  • plemans's avatar
    1. what firmware are you on?
    2. what modem/gateway is it connected to?
    3. how often is it happening?
    4. does it happen to just wired devices or do wired drop as well?
    5. what fixes the issue?
    • santeeslim's avatar
      santeeslim
      Tutor
      1. I have the current firmware, updated when the product was installed about two weeks ago. The modem firmware is V1.01.14
      2. It's connected to the Netgear DOCSIS 3.0 16 DS 4 US modem
      3. It occurs as often as shown in the log file I sent
      4. I don't have any wired devices.
      5. It recovers by itself.
      In addition to this question, I get what appears to be halts for buffering near the beginning of most programs. I say "appears to be buffering because I have no way to know it that's actually what it is.
      santeeslim
      Tutor
      The firmware in my router is Version  V1.1.6.124_2.0.59
      Sorry for the earlier lack of info.
      • plemans's avatar
        so the goal is to figure out where exactly the issue is coming from.
        If you have no wired devices and your getting a lan fail notice, the only thing connected with ethernet is the modem.
        so is the error coming from the modem or the router side.
        Do you have a screen snip of the modems cable connection page and event logs?
        have you replaced the cable between modem/router?
