ChicagOntarian's avatar
Oct 26, 2022
MS60 (MK62 Kit) / Satellites will not sync after automatic Firmware update to V1.1.7.132_2.0.64
Bought an MK62 mesh kit in June and couldn't be happier, good speeds, great coverage, easy to manage.
Six days ago my satellites were both offline (orange indicator lights) and I have been unable to get them synced up to the MR60 since then. Tried factory restes and followed all instructions, they just never sync and indicators never turn blue. Have been using them all with wireless backhaul, and worked just fine. Tried wired backhaul and same thing - will not sync.
I wondered about and looked up the release date on the V1.1.7.132_2.0.64 firmware and it seems that it just came out 10/17/2022. Is that correct? If so, seems almost a no-brainer that something went astray during the auto-update (which I should have turned off anyway, my fault there) and I want to know if anyone else is experiencing this issue and has a fix been discovered. The only thing I have not tried is a clean re-install of the router (after a factory reset) because the MR60 router seems to be working perfectly fine.
Any help is appreciated
