bulldog00
Nov 14, 2021Apprentice
MS80 backhaul issue
Hi all, I have the MK83 mesh nighthawk. I have one MS80 satellite hardwired for backhaul. However, I cannot get the satellite to show a “wired” connection type from its IP interface (or from the garbage nighthawk app). I have ensured firmware is up to date, tried full reset of the entire system and just the satellite, testing and confirmed wiring is not the issue.
There is no option to enable/disable daisy chain with this system.
Any suggestions on how to get the satellite to update the wired backhaul?
quick follow up. Found a bad punch down on the keystone. Problem solved. Thanks again for the support!
You'd think as i am an IT Professional and have loss of feeling in my finger tips from terminating so many cables, id know better...
