Dustin_V
May 20, 2020NETGEAR Employee Retired
Nighthawk Mesh Q&A with Product Manager, Arun K. - May 27 to June 2
Update: The Nighthawk Mesh Q&A has been extended through Tuesday, June 2! Here is your chance to ask your Nighthawk Mesh WiFi 6 System questions to Arun, so don't miss out!
Join us on Wednesday, May 27 from 11AM to 12PM PDT for a Nighthawk Mesh Q&A with Product Manager, Arun Kulathamony. As Nighthawk Mesh quickly becomes a top choice for mesh WiFi, Arun will be on hand to help answer all of your questions about NETGEAR’s latest WiFi 6 Mesh System and to discuss all things Nighthawk Mesh.
To participate, please ask your questions in this discussion thread in advance of the Q&A or during the scheduled date and time. We look forward to having you join the conversation!
Watch our "What is Nighthawk Mesh?" Livestream:
- rrivers2Initiate
Netgear Nighthawk Wifi 6 Mesh Range Extender EAX80
Hardware Version EAX80
Firmware Version V1.0.0.36_1.0.1
I have purchased several of the Netgear Nighthawk Wifi 6 Mesh Range Extender and all units after the initial setup the 5G settings will return to default settings (Netgear-5G). I did notify Netgear and so far they replaced one unit and I have not heard back on a fix. Has anyone else experienced this problem?
- alfred0809Aspirant
I highly recommend AC router in general, Nighthawk and Asus seem to be the go to standard.
What is the meaning of AMA? Can't locate this anywhere in the Nighthawk Mesh marketing, specs, manual ...
In my understanding, the key difference to the Netgear Orbi systems is that we're facing with the Nighthawk Mesh an industry standard WiFi EasyMesh system here. However, no word of this ... probably not certified, but why?
- Dustin_VNETGEAR Employee Retired
AMA (Ask Me Anything) is bascially a Q&A session. In this case, Product Manager of Nighthawk Mesh, Arun, will be tuning into this thread and answering questions. Your question on the difference between Orbi/Nighthawk Mesh and EasyMesh is actually a great question that he will be able to address during Wednesday's AMA/Q&A.
- Phil18TutorHey there, I'm currently running a rax120 and quite happy with that router. I also have in the upper floor a AP that is running the same ssid but by another manufacturer. I'm thinking of switching over to another netgear product and I'm very interested in Nighthawk mesh system. Is it possible to use all the advantages of the mesh system like roaming ethernet backhaul and also wireless backhaul with the rax120 as gateway or do I have to replace the rax120 by the mesh router?
Are you also planning to support VLAN tagging (wireless and lan interfaces) to seperate IoT devices from the rest of the network?
Thank you for taking the time for this AMA- arunkmonyNETGEAR Employee Retired
Phil18 wrote:
Hey there, I'm currently running a rax120 and quite happy with that router. I also have in the upper floor a AP that is running the same ssid but by another manufacturer. I'm thinking of switching over to another netgear product and I'm very interested in Nighthawk mesh system. Is it possible to use all the advantages of the mesh system like roaming ethernet backhaul and also wireless backhaul with the rax120 as gateway or do I have to replace the rax120 by the mesh router?If you are using two routers, you will have issues with double NATing. Roaming and handoff will happen seamlessly between the router and satellite. Ethernet backhaul is also supported using the ethernet port on the router and satellite. Since it's dual-band system, the WiFi backhaul is shared.
Thank you for taking the time for this AMANo problem. :) We are evaluating new features and adding into the mesh system. Will keep everyone posted when available.
- Phil18TutorSo if I got you right I have to replace the rax120 with the nighthawk mesh router to get the full experience with nighthawk mesh system?
Hey folks,
This is Arun.
I'll be available here until noon to answer any questions you may have around the new Nighthawk Mesh WiFi 6 System.
Looking forward to seeing you here..
Originally asked by: hkstreetname
Can Nighthawk MK63 support two wired backhaul (ethernet backhaul) to connect to its satellites?
Dustin_V wrote:Originally asked by: hkstreetname
Yes, hkstreetname . It's possible to use a switch between the router and satellite. Hope you find this mesh system suitable for your needs.
- FscscottAspirant
Can you discuss the differences between a Nighhawk setup and the Orbi setup? Trying to understand which is the bext option for my house and my families use. I have a single story 1500sq/ft house with some outdoor space we'd like coverage in. Thanks.
Fscscott wrote:Can you discuss the differences between a Nighhawk setup and the Orbi setup? Trying to understand which is the bext option for my house and my families use. I have a single story 1500sq/ft house with some outdoor space we'd like coverage in. Thanks.
Fscscott Nighthawk Mesh and Orbi WiFi 6 both support WiFi 6. The Nighthawk Mesh is a dual-band system while the Orbi WiFi 6 is a tri-band system.
For a small to medium home with a 100-300Mbps internet connectivity, you may find Nighthawk Mesh as a good option. For a larger house with gigabit internet connection the Orbi WiFi 6 RBK852 may be a better option since there is a 2.5G port for the WAN. Another thing to consider is number of wired devices. NIghthawk Mesh has 1 lan port each on the router and satellite while Orbi RBK852 has 4. Orbi is installed and managed using the Orbi app while Nighthawk Mesh is installed and managed by the Nighthawk app. In both the systems, you can add additional satellites to extend coverage as needed.
- akongGuide
I bought into this system thinking that it will have better signal strength and range (and thus better stability) than my single C3700 cable modem router. I was very disappointed to continue to experience frequent intermitten disconnections with my mobile devices regardess of distance within my 2 story 2500 sq ft home. Using only the modem router WIFI, I never have a disconnection issue other than weaker signals on the 2nd floor. With the Mesh Wifi 6 router system (updated with the latest firmware), I have the satellite on the 2nd floor and the router wired to my modem with the modem's WIFI is turned off. When using the cable modem router only, I have solid signal in my kitchen on the first floor. Using the MR60, my Galaxy S9+ indicated a good link rate, but when it comes to connectivity on games/apps, they keep getting disconnections. The knighthawk app is sometimes working with the router and not working at other times. If anyone is looking to invest in a wifi 6 mesh system to future proof, you may want to consider twice. With the modem router, configuation update is within 10 seconds. With the wifi 6 mesh system, configuration update for even a small change (like a checkbox to enable some feature) takes more than a minute.
akong
akong wrote:I bought into this system thinking that it will have better signal strength and range (and thus better stability) than my single C3700 cable modem router. I was very disappointed to continue to experience frequent intermitten disconnections with my mobile devices regardess of distance within my 2 story 2500 sq ft home. Using only the modem router WIFI, I never have a disconnection issue other than weaker signals on the 2nd floor. With the Mesh Wifi 6 router system (updated with the latest firmware), I have the satellite on the 2nd floor and the router wired to my modem with the modem's WIFI is turned off. When using the cable modem router only, I have solid signal in my kitchen on the first floor. Using the MR60, my Galaxy S9+ indicated a good link rate, but when it comes to connectivity on games/apps, they keep getting disconnections. The knighthawk app is sometimes working with the router and not working at other times. If anyone is looking to invest in a wifi 6 mesh system to future proof, you may want to consider twice. With the modem router, configuation update is within 10 seconds. With the wifi 6 mesh system, configuration update for even a small change (like a checkbox to enable some feature) takes more than a minute.
akong , sorry to hear you are having problems with the Nighthawk Mesh system. Please reach out to Netgear support to create a case so we can help to understand your problems and try to fix them.
Originally asked by JHAnd:
I purchased two AX1800 MK63 sets from Costco. Can I use the second router as a satellite? Does it need to be set to bridge mode? How many satellites can I add in total? Can I hard wire one of the satellites or the second router to help boost signal across the house?
Original thread: https://community.netgear.com/t5/Nighthawk-Mesh-System/AX1800-MK63-how-many-satellites-can-I-add/m-p/1922015#M386
- JHAndAspirantArun.... any comments or answers to my questions from earlier.
Thx- arunkmonyNETGEAR Employee Retired
Dustin_V wrote:Originally asked by JHAnd:
JHAnd , the router on MK63 cannot function as an additional satellite. You can use the satellites from the second kit to pair with the first kit using the sync/Add Satellite from the Nighthawk App using a wired or wireless connection. It's recommended to limit the number of satellites to 3 or less to get the best performance/coverage.
- akongGuide
Question 1 : This is related to this community thread (Q&A with Product Manager), why is the model not listed in the popup list to pick for the Nighthawk Mesh Wifi6 System (MR60, MS60)? Isn't this the system we are wanting to discuss on this thread?
Question 2: If AX is backward compatible, we do we still need to enable or disable AX feature on the router?
Question 3: Where is there an option to disable beam forming if it is support to be good in extending range?
Question 4: Are you aware of the intermitten disconnectivity issues reported by the communicty that is inherent in the MK6x system?
- akongGuide
Corrections to typos:
Question 1 : This is related to this community thread (Q&A with Product Manager), Why is the model not listed in the popup list to pick for the Nighthawk Mesh Wifi6 System (MR60, MS60)? Isn't this one of the system we are wanting to discuss on this thread?
Question 2: If AX is backward compatible, why do we still need to enable or disable AX feature on the router?
Question 3: Why is there an option to disable beam forming if it is supposed to be beneficial to all wifi devices?
Question 4: Are you aware of the intermitten disconnectivity issues reported by the community that is inherent in the MK6x system? There are several YouTube videos indicating such issues. Will this be addressed? Some says it is due to double NATing, but why is this intermittent? If it is double NATing issues, it should either work or not work but not intermittent, correct?
akong wrote:Question 1 : This is related to this community thread (Q&A with Product Manager), why is the model not listed in the popup list to pick for the Nighthawk Mesh Wifi6 System (MR60, MS60)? Isn't this the system we are wanting to discuss on this thread?
Dustin_V , kindly check this issue.
akong wrote:Question 2: If AX is backward compatible, we do we still need to enable or disable AX feature on the router?
No, WiFi 6 or AX will automatically detect previous generation 11ac devices and connect and function normally. The checkbox can be left in its default ON position. Turning off is for debug purposes.
akong wrote:Question 3: Where is there an option to disable beam forming if it is support to be good in extending range?
akong , please refer to the User Manual for configuration options. It's listed on the UM page 74.
akong wrote:Question 4: Are you aware of the intermitten disconnectivity issues reported by the communicty that is inherent in the MK6x system?
Yes, we are actively looking into all issues faced by customers related to the Nighthawk Mesh system. As always we are trying to improve firmware so our customers can get the best experience with the product.
If anyone is facing an issue, please reach out to NETGEAR support team so that we can get it working for you. We are looking for volunteers who can work with our tech support and engineering team to debug disconnect issues faced by them.
- AlexEsparzaAspirant
Dustin_V wrote:Update: The Nighthawk Mesh Q&A has been extended through Tuesday, June 2! Here is your chance to ask your Nighthawk Mesh WiFi 6 System questions to Arun, so don't miss out!
