hewepr1
Jun 08, 2021Aspirant
Nighthawk MK63 - can I connect the satellites via Ethernet (not wireless)?
I am considering purchaisng the Netgear Nighthawk MK63 pack (One router and two satellites) ;-I dont have the budget for Orbi.
I've googled for an hour or so and read the installation and user manual for the nighthwak Mesh AX, but it doesn't seem to clearly define whether the satellites can be connected by Ehternet to the router?
I'm my environment I have a need to have one satellite connected by ethernet and one via Wifi.
Is this possible and if so -will i have an issues by doing this?
NOTE: I couldn't find a matching model number in the list - sorry if this has confused things.
For the sake of clarity - this is the product:
https://www.netgear.com/au/home/wifi/mesh/mk63/
Cheers
Pete
- hewepr1Aspirant
Thanks PLemans, you truly are a guru. ONe final questions if I may - if I want to connect both the Satellite, can I introduce a gigiabit switch between the router and both the satellites ?
ie :
Router -> gigbabit switch ---> Satellite 1
---> Satellite 2
Will that should work ?
Best Regards
Pete
- Christian_RNETGEAR Employee Retired
Hello hewpr1,
We have receive positive feedback that users we're able to accomplish this setup.
Christian
