Gatesway's avatar
Gatesway
Nighthawk MR60 Slow wifi internet speed on Mac
When running speed test, at modem I have 100 down, 20 up.  Using the MR60 on WiFi (I'm sitting next to router running V1.0.6.102) it is rare to even get 20 down - usually 15-16.  I've made sure the firmware is up to date.  I've looked in settings.  Nothing helps me to understand the huge drop in speed.
Something else is weird, if I run speedof.me on my Mac, I'll get 15 down & maybe 18 up.  On my iphone, same results.  When I do a speed test on the Nighthawk app on the iPhone, it is 76 down & 20 up.  Then if I use AT&T's app (Smart Home Manager) it shows 100 at the Modem & maybe 26 down/20 up at the device (iPhone or iPad).
Again, all of these tests are done in the LR next to the modem  where the router is plugged in.
I'm using a Mac running BigSur 11.1 - but the same results are found on my iPad or iPhone XR running 14.2).
  • plemans's avatar
    what modem/gateway are you using?
    Also, are you connected to the 2.4ghz or 5ghz?
    what speeds do you get hardwired into the MR60?
    • Gatesway's avatar
      Gatesway
      It is an AT&T modem (UVerse) BGW210-700.
      I'm connected to 2.4ghz.  DOn't know how to change to 5ghz.
      Have not connected "hard-wired" to the MR60.  Did not think I needed to.
      Thanks for any help!
      • plemans's avatar
        Gatesway wrote:
        It is an AT&T modem (UVerse) BGW210-700.---which has its own integrated router and can cause issues with double nat.
        https://kb.netgear.com/30186/What-is-Double-NAT
        I'm connected to 2.4ghz.  DOn't know how to change to 5ghz.----it should bandsteer to 5ghz as needed. but if its on 2.4ghz, yours speeds will be slow. 2.4ghz is a slow network and sensitive to interference.
        Have not connected "hard-wired" to the MR60.  Did not think I needed to.----You don't need to but for testing, its a good way to ensure the router is getting full speeds.
