MaineBear's avatar
MaineBear
AC1900 vs AX5400 gaming router
I currently have the AC1900 Nighthawk router.  A friend told me I should upgrade to the AX5400 gaming router.  What differences in performace will I see in the two and what other differences will there be?  Is it worth the extra money to upgrade?
We have 2 Xboxes, 2 PC's and 2 Nvidia Shields.   All are on 4k TV's.
Thanks for the advice.
  • plemans's avatar
    Is the $ worth it? Depends. You might get some lower latency/ping times. You can also choose gaming servers to help with that.
    but is it worth the money? That's a loaded question that usually a significant other is better positioned to help with. :)
    If you're streaming/gaming devices aren't hardwired in, you might find a better benefit from hardwiring in devices than upgrading its wireless. since I doubt the tv's or shields are AX devices.
    are you having issues? Or just curious?
    • MaineBear's avatar
      MaineBear
      We aren't really having any problems, so I guess just curious.  LOL.  We do have an issue with quite high latency.
      • plemans's avatar
        What router and modem/gateway do you have
