mataychic88's avatar
mataychic88
Dont working xr500
Good day community! I have a problem with the XR500 router. Stopped working normally. It does not load to the end, does not work wifi, does not go to routerlogin and does not ping its IP address. When turned on, power lights up in orange, and after 15 seconds any connected cable (1-4). 2 flashing options did not work. The reset did not work. It goes into flashing mode when holding the reset and turning on the power (in white).
What do you suggest to do? try sewing via USB UART? Sorry for the language, translated by a translator
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Does the Power and  internet LED on the top show AMBER or WHITE?
    • mataychic88's avatar
      mataychic88
      The power LED at the top is yellow.
      The Internet LED does not glow in any color.
      Does not go to factory settings, after resetting the problem is the same.
  • Do you have it connected to a power extender or direct to an outlet? If an extender please try direct to an outlet. Otherwise do you have another power adapter you could try with?
      mataychic88
      I connected it to directly to the outlet. I will try to access the power supply parameters through the voltage converter. I'll write back later.
      • FURRYe38's avatar
        Make sure power adapter is connected to a 110V power supply or source. Review the Power adapter sticker for power voltage and amp input requirements.
