zouguanmin
Aug 18, 2021Tutor
Help, the XR700 upgrade version cannot be online
XR700 original version 1.0.1.20 Everything is normal but the upgrade is 1.0.1.38, it is normal but the next day, it is not possible to go to the original 1.0.1.20. It is not possible to brush various versions to recovery the factory settings cannot be DHCP. Successful connection but unable to connect to the Internet with AP mode computer can not access the mobile phone can not router mode.thanks help
- omg,router no work again i didn't do anything today in the noon time router no work u can see the picture same yesterday no work
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will ask the Netgear moderator to move your message. - Netduma-FraserNetDuma PartnerSorry can you clarify the issue you're having? It's hard to understand the exact problem from what you've written so far
- The problem is that the router cannot access the Internet after I upgrade, even if I roll back the version and restore the factory settings.
- Netduma-FraserNetDuma PartnerDid you factory reset after the update? That is recommended after an update. Also what is your ISP modem/router?
