Blondozavr
Sep 10, 2024Aspirant
Netgear Night Hawk Xr1000 OFDMA lag in game
Hi.
I have a problem.
When I turn on OFDMA my ping in games starts to increase. I play on Playstation 5 connected via 5ghz wifi.
Geo-Filter - off
QOS - off
Internet Connection - 935/935
Channel 44.
Router version XR1000 1.0.0.74_1.0.63
I have a problem.
Geo-Filter - off
QOS - off
Channel 44.
Leave it off?
Ethernet connect the console to the router instead?
- BlondozavrAspirant
Hi!
Thanks for the quick response.
Now the console can't even connect to the network with WIFI 😞
- Netduma-FraserNetDuma PartnerThat may or may not be a cause, could be incidental but you've disabled the two features that would help you keep your ping low so I'd suggest using them and see if you get the same issue.
Hi.
Just turned it on:
- Geofilter
- QOS
The console does not connect to the network.
As soon as I turn OFDMA off everything works fine.
- Netduma-FraserNetDuma PartnerAre you adjusting the option while the console/game is on? If so reboot the console then check.
