Wirus
Oct 04, 2022Tutor
Netgear xr1000 Downlad speed slow
Hi, having an issue with my Netgear xr1000. Recently i,ve updated my internet plan to speed of 330 mb/s download and 42 mb/s upload. Now when i use the benchmark from DumaOS it shows that i have speeds of 42 mb/s download and 9 mb/s upload which is correct. Now the issue is that my download speed do not exceed 4 mb/s when downloading a game for example. I've tried different settings on DumaOS but it's the same. Whwn i connect to my internet provider modem i get the full speed but trough xr1000 i don't.
Firmware vers is 1.0.0.64_1.0.49. I am using the 2.4 G for most of my in house devices and 5G for my PC and Phones. My pc is connected trough Wireless connection and cannot use LAN because atm i don't have a LAN cable that long. The router and PC are in the same room. Thank you
- Netduma-LiamNetDuma Partner
You mention that the speeds you get in Connection Benchmark are 42Mbits which is correct, but that doesn't sound correct, you say you've upgraded to 330Mbits? If there's a reason you'd expect the XR to be getting much lower speeds than this can you let us know?
Also, what game client/service are you downloading through? For example, Steam, Battle.net, Origin, etc?
- WirusTutorWell yes. I’ve upgraded to 330 mb/s but the this numbers are give by the internet provider and to get the real speeds those numbers needs to be divided by 8. I am using Battle.net and Ubisoft clients.
- Netduma-FraserNetDuma PartnerCan you provide a screenshot of your QoS page please? Are all devices connected to the XR or are some still connected to the hub? Have you put the XR in the DMZ of the hub?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.A wired speed test should be performed with the PC to check wired speed results.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
- WirusTutorThe modem is from BT (UK) smarthub 2 and the cable i’m using between the modem and NG is the one that came inside the router box. I will try doing the steps u mention and come back to let u know if this will work. Thank yo
Usually SmartHub modems have WIFI and routers built in. IF this is the case, This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
