Tony-Dewhurst's avatar
May 12, 2019
Netgear XR700 Sluggish Performance and Losing WAN
Having a few issues with the router done the same test with a R7000 with Merlin  WRT and there are no issues..
Is this expected performance fto 100% cpu from a xr700 downloading a single torrent file?
This usually ends up with a locked router admin page and a reboot is required.
On Latest firmware and done factory reset.
  • This sounds like something you might need to contact NETGEAR support about. This router should be able to handle much more than you're throwing at it here.
  • FURRYe38's avatar
    Try downgrading FW to 1.0.0.20
    FYI, (x)WRT is not supported on the R7000...So test comparison isn't really valid.
