t0ny
Mar 21, 2018Apprentice
Nighthawk XR500 USB Control Center not recognizing my printer
Router : Nighthawk XR500 OS : Windows 10 Printer : Samsung ML-2165 I tested the USB ports and they recognize the Flash drives, but when I plug in the printer , there is no light on the router ...
- Apr 04, 2018
NETGEAR confirmed that the ReadySHARE Print feature was mistakenly removed from the XR500 firmware and it will be restored in the next offical firmware release. We just need to sit tight for the next XR500 firmware release.
t0ny
Mar 27, 2018Apprentice
Forgot to mention first I did upgrade to the newest version as well but that didn't help as well.
Also the printer works fine when connected to USB ports on my laptop. So nothing wrong with it or the cable.
Tested both USB ports on the router, both ports won't light up. But they don't seem to have a problem recognizing the flash drive.
And yes, only one device at a time yes.
I really wanted to be able to use my wired printer wirelessly...
Netduma-Fraser
Mar 27, 2018NetDuma Partner
Hi t0ny, I am not familar with the USB side of things as it's a Netgear feature. Did you call or email support? If you call you should get a higher level of support.
In USB Storage > USB Settings is enabled set to yes? If you click Approved Devices do you see the printer listed?
- t0nyMar 27, 2018Apprentice
Hi, the support I am getting is trough email messages.
Yes, the USB settings is set to Yes. In approved devices there are no devices listed. If I choose Add devices then it ask me to choose a device but since there are no devices listed I can not choose a device.
To me it seems that the router doesn't recognize the printer at all as the light doesn't turn on... I even tried a different printer, same thing. I wanted to ask if anyone else is experiencing the same issue with their printers, hence posting it here on the community forums or is it my router / settings only?
- Netduma-FraserMar 27, 2018NetDuma PartnerI'd suggest calling instead of support conducted through email.
Also download the Netgear Genie app and click airprint on that and see if you can resolve it that way. - JasonNMar 27, 2018NETGEAR Employee Retired
Hi t0ny,
Contact support and they will be able to help you with the issue.http://www.netgear.com/support/contact.aspx
Thank you for posting on the community. :]
- Jason N
- JasonNMar 30, 2018NETGEAR Employee Retired
Hi t0ny,
Just wanted to check in and see if the support team has fixed your issue.
Please let me know. :]
- Jason N
- schumakuMar 30, 2018Guru - Experienced User
JasonN wrote:Just wanted to check in and see if the support team has fixed your issue.
JasonN Whatever kind of magic support fixes is not the deeper sense of a community. Please share here what XR500 owners experiencing the same problem have to do to make the USB Control Center recognizing the USB port over the Ethernet. Thank you.
PS. Nether quoting with the username link nor using the UserName form is accepted - HTML is still refused in this forum.
