t0ny
Mar 21, 2018Apprentice
Nighthawk XR500 USB Control Center not recognizing my printer
Router : Nighthawk XR500 OS : Windows 10 Printer : Samsung ML-2165 I tested the USB ports and they recognize the Flash drives, but when I plug in the printer , there is no light on the router ...
- Apr 04, 2018
NETGEAR confirmed that the ReadySHARE Print feature was mistakenly removed from the XR500 firmware and it will be restored in the next offical firmware release. We just need to sit tight for the next XR500 firmware release.
Netduma-Fraser
Mar 27, 2018NetDuma Partner
Hi t0ny, I am not familar with the USB side of things as it's a Netgear feature. Did you call or email support? If you call you should get a higher level of support.
In USB Storage > USB Settings is enabled set to yes? If you click Approved Devices do you see the printer listed?
t0ny
Mar 27, 2018Apprentice
Hi, the support I am getting is trough email messages.
Yes, the USB settings is set to Yes. In approved devices there are no devices listed. If I choose Add devices then it ask me to choose a device but since there are no devices listed I can not choose a device.
To me it seems that the router doesn't recognize the printer at all as the light doesn't turn on... I even tried a different printer, same thing. I wanted to ask if anyone else is experiencing the same issue with their printers, hence posting it here on the community forums or is it my router / settings only?
- Netduma-FraserMar 27, 2018NetDuma PartnerI'd suggest calling instead of support conducted through email.
Also download the Netgear Genie app and click airprint on that and see if you can resolve it that way.
