Matt_007
Mar 29, 2019Tutor
PlayStation remote play issues with XR500 router
I have been given an XR500 nighthawk from a friend as I was thinking of buying a x10 but since changing I can't use remote play anymore from out side connection.. I seen an answer to problem on her to do a DMZ ip for PlayStation and this doesn't some the problem and could not reply to the thread, any ideas? But issue is annoying me and will go back to Vodafone router and not purchase an x10 if can't solve ...
- I have now fixed issued yesterday I purchased a dm200 router/modem run in modem mode got username and password from Vodafone and everything works, and the net is 10x faster in general..
Just unfortunately the psn servers went down last night so after hours of messing about with router found out I was wasting my time đ
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so,Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.- Matt_007TutorHi and thanks for the reply the firmware is v2. 3.2.40 and updated when I set it up.
I used the set up wizard to get the router working. And then put the Vodafone router into modem mode as per Vodafone tech support advised me. They also gave me network username/password if I needed.
The DMZ server I have set up I have put the Ps4 ip into.- Netduma_JackNetDuma Partner
Also make sure UPNP is enabled on your XR500. Also port forward 9295 (for TCP), and 9296 and 9297 (for UDP) to your PS4's IP address and see if that works.
If the modem IS fully bridged, DMZ is not needed on the router. Just uPnP.
What you might do is set the modem back to router mode. Connect the PS to the modem. Does it connect then? If so, reconnect the XR router to the modem. Keeping the modem in router mode. Then use the Modems DMZ for the IP address the XR router gets from the modem. Input this IP address into the modems DMZ. Connect the PS to the XR router. DO not put the PS IP address into the XR DMZ. I would reboot modem, router and power OFF the PS. Wait for the modem and router come back to ready. Power ON the PS and test.
- Matt_007TutorI have gone back to original Vodafone router and works, then gone back to the NETGEAR and no connection, checked all ip address ect.. Other places I'm starting to see that it's the Vodafone router is the issue,
I have an old bt router and user name and password, but if its a 10 year old router will that effect the speed if its just in modem mode?- Netduma-FraserNetDuma PartnerAs long as it can handle your speeds it should be just fine to use the BT router.
