Netduma-Fraser
Dec 17, 2019NetDuma Partner
Please read if you're experiencing DumaOS not loading/login interface issues
We have received multiple reports about these issues. I have reported this to our team as this seems to be affecting a few people today, please follow these instructions provided as a workaround while we investigate. Please try a factory reset first before trying this workaround using the button at the back of the router and holding it down for 30 seconds then allowing 1-2 minutes for boot up before accessing:
1. Go to http://routerlogin.net/adv_index.htm
2. Administration -> Firmware Update
3. Download this firmware (two versions below .56*) http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.32.zip
4. Unpack the .zip file
5. Browse to Image file
6. Upload
7. Go back to Administration -> Firmware Update and disable Auto Upgrade until we can say this has been resolved.
If you receive any errors on the .32 firmware then you may need to clear the cache/cookies on your web browser, if that doesn't solve it then do a factory reset, that should ensure no legacy issues have carried over.
We are sorry for any inconvenience this may have caused and will investigate this issue ASAP.
*This version lacks some security updates but this is unlikely to affect you as well as some features (e.g. Ping Assist & Device Manager Table View) from the .56 firmware.
well thank you . I aleady factory reset so that means i have to do all my settigs again ?? not very tech savvy :/
- Mark9816Apprentice
Thank you reseting the frimware fixed the login issue please email me when you have a new firmware fix to totaly solve the issue.
- baezrogelioAspirant
thanks for the info. was going crazy thinking there was somthing wrong with my router. phew. where can we go for notifications of when a fix is found? I kinda don't like running outdated os, but will til it is resolved.
- RiftDragonAspirant
Confirmed that for me as well, the 2.3.2.32 firmware works, but anything more recent than that breaks DumaOS as otherwise described (unable to log in / endless redirects).
- Netduma-FraserNetDuma PartnerIf you have factory reset you will have to redo your settings yes.
We'll post on the forums when a fix has been done.
- StarworshipperInitiate
Same issue, just chiming in.
Factory reset DID NOT work.
Downgrading the firmware DID work.
Time to spend a good hour or two resetting my configuration. Feelsbadman.
- Netduma-FraserNetDuma Partner*Update* We have identified the issue and we are working on an immediate fix. We will update this post with further information when it is safe to reupgrade back to .56. Thank you for your patience.
- LevelUpLiam24Apprentice
Had the same problem this morning, I can confirm the solution.
Downgrading the firmware to V2.3.2.32 resolved the issue.
Remember to deactivate router auto firmware update if it's enabled.Awaiting a fix for this issue. Thank you!
- Netduma-FraserNetDuma PartnerPlease see the post above yours for the link to the fix. Essentially if you re-upgrade back to .56 it should now work fine for you.
- CreXxtonTutor
Having same DumaOS not loaded yet! over and over
- CreXxtonTutor
Your fix did the trick for me. Up and operating. Turning it on and off was well within my capabilities - thanks! Now if I could just find the Tizen that's running on my network!?
