  • Netduma_Jack's avatar
    Netduma_Jack
    NetDuma Partner
    I recommend you downgrade back to an older firmware, and once that's complete, upgrade to the latest version again. To do th:
    1. Download this firmware: https://kb.netgear.com/000059151/XR500-Firmware-Version-2-3-2-22
    2. Go to http://routerlogin.net/adv_index.htm
    3. Go to Administration then Firmware Update
    4. Now upload the firmware you downloaded on step 1
    5. Wait for installation to complete
    6. Now try going to routerlogin.net like normal - does Settings load now?
    7. Hopefully it does, if so, got Administration then Firmware Update, and then install the latest firmware: https://www.netgear.com/support/product/XR500.aspx#Firmware%20Version%202.3.2.32
    If that does not fix the problem then there are two other possible causes I can think of:
    - You have an adblocker/security/firewall extension preventing it from loading. Could you try temporarily disabling it to see if that fixes your problem
    - You are using an incompatible browser. Try using Chrome or Firefox (if you're not already) to see if that solves it
    • angry55's avatar
      angry55
      Hello,
      thank you for your assistance. much appreciated
      before I downgraded / upgraded the firmware I tried disabling the adblocker
      this allowed me to see the settings menu in dumaos
      as a precaution I downgraded / upgraded the firmware as well
      I have now setup an exclusion in the adblocker and all seem to be working ok
      however I still have a concern that the settings and process manger rapps still have a play button beside their names where all the other rapps have a pause button
      any suggestions
        Netduma_Jack
        NetDuma Partner
        That's great news that you found the problem.
        Don't worry about the play/pause icon. That's the default way we present it.
