UTLEYM
Mar 09, 2021Aspirant
Router keep dropping LAN connection with XBOX series X
For whatever reason, this router keeps dropping LAN connection. I have 1 gig internet. I have no idea what is going on.
- Netduma-LiamNetDuma Partner
Sorry to hear this!
It is just with the Series X? No other devices are losing connection? Do you have access to the interface when the drops occur?
- jonbusinessacctAspirant
This was plauging me for several months and I found it was Netgear's security software. 10x speed improvements once these fixes were enabled.
Advanced Setup
Disable QOS
Disable Port Scanning and DOS Protections
Respond to Ping on Internet Port
Disable IGMP Proxying
Disable SIP ALG
- UTLEYMAspirantThis didn’t work. Thank you for the recommendation though!
- UTLEYMAspirantNo my wife was having issues this morning as well. I just bought this thing. One thing I did notice is that the white blinking LED will turn amber?
- UTLEYMAspirant
Do you get that question mark when you try to access the interface during a drop or is it all the time? What firmware version are you currently running?
