shawnn007
Jul 07, 2018Initiate
Router to work with TCL Roku enabled TV
Hello,
I am trying to set up my new XR500, it is some what slow on most my wifi devices ( phones, tv's, ect non gaming devices) but they do work. My main problem currently is that when I have my TCL roku Tv ( brand new) connect to my wifi or wired in it will not allow me to open Prime Video (amazon video). I think it is one of the settings off with my router or how strict my router is but I have changed multiple settings and nothing is working. i have tried connecting it to my 2.4ghz wifi under channel 11 as recommended bu that does nothing, also have connected to 5ghz wifi and it does not work either. i think that the setting or stictness the router is also the cause of all my devices being slow. I am currently running 450mbps spectrum internet.
When I open amazon prime it just loads for a long time then say no network detected. I know it is not the tv because i can connect it to another internet source and it opens up immediately. I also know it is not the internet because Prime video will load on my other Smart tv (LG TV). I am thinking it has something to do with the router security or firewall or fireware blocking it. i am wondering if port forwarding would help but i can not find any info on Amazon servers or Prime video Serves to add the ports into the router.
Any advise would be great.
Thanks,
Shawn007
- Netduma_JackNetDuma PartnerHi Shawn - what is the make of the modem your XR500 is plugged into? If it’s a modem/router combo, it’s possible you have double NAT.
The best thing to do is go on your modem/router and enable ‘Bridge mode’ or ‘modem mode’
What’s the exact error message you are getting on Roku?
Also, can you connect it directly to your modem? If yes, does it work?- shawnn007Initiate
the modem I have was provided my spectrum it is an Arris model TM1602A, it is a stand alone modem. Spectrum offered a sperate router but i decided to go with the xr500 so i do not think there is a double nat issue. I believe the Prime video issue is something to do with Prime Video and the Xr500 Router bc everything else works on my TCL tv but Prime and i have even hard wired the tv to the XR500 router to see if it was a wifi issue and it still does not load.
the exact error I am getting on Prime is "internet Connection Error"
even my LG tv is running Prime Video Slow. It use to open fast on my old internet with that modem/router combo from Windstream and i was only running 40 MBPS internet then. i have since upgraded to Charter Spectrum 400 MBPS package.
i do believe it has to do with the xr500 settings.
like i was saying all my wifi devices are running slow( non gaming devices) but my gaming computer is running great at the full 400 mbps speed.
- Netduma-FraserNetDuma PartnerHi shawn, go to Settings > WAN Setup and make sure "Disable IGMP Proxying" it unticked. Does that resolve your issue?
