qasim9
Aug 02, 2018Aspirant
rx500 and alcatel G-240w-b
أنا من المملكة العربية السعودية .. لدي xr500 نوع من ألياف الاتصالات الكاتيل G-240w-b نوع الاتصال جسر و دعم شبكة محلية ظاهرية لدي مشكلة في توصيله ps4 اتصال pppoe لدي اسم المستخدم وكلمة المرور isp ولكن لا يمكن الاتصال بـ PS4 لا يمكن الحصول على nup tupe 1؟ ما هو الحل ، وأفضل طريقة للاتصال؟
I'm from Saudi Arabia .. I have xr500 type of communication fiber Alcatel G-240w-b type bridge connection and support VLAN I have a problem connecting it ps4 connection pppoe i have a username and password isp but can not connect to ps4 can not get nup tupe 1? What is the solution, the best way to communicate?
- Netduma-FraserNetDuma PartnerYou wont get NAT Type 1, that just means connected to the modem. NAT Type 2 is also open, just means connected behind a router. Do you have internet through the PS4?
- qasim9Aspirant
Yes but I'm having a high ping ,, I want the best way with modem alcatel fiber, do you by bridge, pppoe?- Netduma-FraserNetDuma PartnerOkay you need to start with the exact issue you're having and more details. What games are you playing? Are you using QoS or the Geo-Filter? Do you know if you have PPPoE?
