AzureTorisuna
Sep 02, 2020Tutor
Slow Internet speeds Wired
Alright so I have spent a couple of minutes browsing through the forums here and I cant seem to see one that solves my issue. I have determined that the bottle neck is indeed the nighthawk. I get my speeds from the modem when I wire into just the modem with my desktop. Then when I plug in the desktop to the xr300 it then gets a fraction of the speed I should be getting. This goes for all devices wired or connected wirelessly. I have 1gbps down. But when I wire in through the xr300 I get maybe 60mbps or 150mbps at best. I did have Qos on but for testing I turned it off and nothing changes. Can someone that knows whats up help me troubleshoot this. Its maddening.
- There is one port limited to 100Mbps which would prevent you from getting higher speeds. Can you try another cable please at least Cat5e in a different port and see if the speeds increase?
try following this guide on optimizing the settins and bandwidth.
- Netduma-FraserNetDuma PartnerDid you turn it off completely in the Anti-Bufferbloat 3 line option menu?
Like change it to Never? Yes if so and also I triple tried the above guide and what not. Cant get the situation to improve.
Edit: Sorry I now see that you can further disable it and Yes I did do this and nothing has improved.
The guide did not help after following all of the provided steps. I disabled the residential gateway from my modem, changed Qos settings and everything. Still no improvement.
