gamer_316's avatar
gamer_316
Slow speeds on XR300
Been looking across the internet to try & find solutions to my speeds being slowed down to half or less from what I was getting before. I moved into this apartment where the equipment wasn’t mine & I was getting 130mbps down on my PS4 & skip ahead to now I’ve replaced the equipment with a CM1200 modem & XR300 router & at this moment I’m getting speeds around 70 on my iPad & around 40 (Wired) on my PS4Pro. I was messing with the settings the other day & it seems like a glitch happened where the R-Apps weren’t working but doing speed tests I was getting 130 on all my devices. One of my roommates restarted the router this morning not knowing there was an internet outage & now I’m back down to my speeds being cut. I’m pretty sure it’s something in the settings but I can’t figure out what exactly. Please help. I prioritize my PS4 over everything else.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Would suggest using the guide above. How exactly have you given priority to the PS4?
    • gamer_316's avatar
      gamer_316
      After doing speed tests on my PS4 via being connected to the modem I ran 5 tests and I got 119.7Mbps, 348.8Mbps, 353 Mbps, 151.4Mbps, and 357.5Mbps. I had my PS4 prioritized from the QoS giving my game consoles the most bandwidth usage. I haven't changed anything yet for the optimal settings yet to allow the speeds come through properly and the firmware is on whatever the newest firmware to date, I don't have a PC or laptop so I don't think I'd be able to install an older firmware if all else fails.
      • plemans's avatar
        And what speeds do you pay for?
