PSling's avatar
PSling
Follower
Aug 09, 2019
Some devices can't see the wireless network
Hi All, I just purchased and connected a XR500 to the NBN (australia) and for some reason almost every device can connect perfectly to the router but I have 2 HP PC's and one Ring Doorbell that when they search for available networks the Nighthawk wireless isn't available to select. I have multiple phones, ipads, laptops and xbox's that all see and connect without a issue. Any help appreciated. Paul
  • Could you disable Smart Connect in the WiFi settings please and connect to the 2.4/5GHz WiFi manually and see if they're all able to connect then please?
    • chall1029's avatar
      chall1029
      I have the same problem. Just a few devices can’t see the network. Always the same devices.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Have they ever been connected at all? You may need to forget the connection on the devices itself and then try to reconnect with the password.
