WillDahBeast
Oct 29, 2022Aspirant
xr 500
Hey everyone!
I've had this problem for about 2 years now and have just kinda dealt with it.
Trying to login to WebGUI I get error
"DumaOS not loaded yet!
Don't worry we will redirect you shortly."
It never does anything past this, i've tried factory resets. Pretty much a bricked router.
Anything else I could try?
WillDahBeast wrote:
Hey everyone!
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads. - plemansGuru - Experienced User
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash- WillDahBeastAspirantThanks for the reply.
I did as instructed but get a "connect request failed" when trying to send the firmware with CMD.
I am able to ping the device, and I have waited for a reboot and orange LED on power.- Netduma-FraserNetDuma PartnerDid you set the static IP correctly on your ethernet adapter as well as ensuring you're in the right directory where the firmware file is?
- Netduma-FraserNetDuma PartnerGenerally a reboot, then waiting 2 minutes before accessing should resolve it but if not then the TFTP method above is a good idea
