FreddieS's avatar
FreddieS
Apprentice
Feb 15, 2025
Xr1000 V2 having DNS issues and unable to connect to websites
I just bought this router and i am having some series issues. I have updated to the latest firmware and did all the suggested things. Is anyone else having these issues and has anyone fixed it?  I have a open ticket with NG. Thanks.
  • plemans's avatar
    Try a different DNS Server. Here's a few. Also remember to change the ipv6 dns server if ipv6 is enabled.
    CloudFlare
    IPv4: 1.1.1.1 and 1.0.0.1
    IPv6: 2606:4700:4700:0:0:0:0:1111 and 2606:4700:4700:0:0:0:0:1001
    GoogleDNS
    IPv4: 8.8.8.8 and 8.8.4.4
    IPv6: 2001:4860:4860:0:0:0:0:8888 and 2001:4860:4860:0:0:0:0:8844
    • FreddieS's avatar
      FreddieS
      Apprentice
      I currently have it on Googles DNS. Still same issue. I contacted my ISP and they are sending me out a new modem. I do not have v6 enabled. And i did not change the pool to 100 - 200 this time around. My Firmware is 1.1.0.22_2_1_34 .   It does say there is a firmware update on top but i am assuming to ignore that?   The update it wants to give me is 1.1.0.16_2.1.25 .
      • plemans's avatar
        what modem do you have?
        does it work if a pc/laptop is directly connected to the modem?
        It shouldn't be asking you to update if you're actually on the latest. I'm wondering if maybe you have those backwards?
  • By the way, while I've got some knowledgable folks available, what's the best/proper order to connect the following for both network effeciency and to prevent issues like flooding and loops, etc.?
    1. Cable Modem: Xfinity XB8 with 4 gigabit ethernet ports
    2. Main Router: either NetGear XR1000v2 or the TP-Link Archer C7 AC1750
    3. Main Switch: NetGear GS108 8-port unmanaged switch
    4. Second Switch: Generic 5-port unmanaged switch
    5. Second Router: Archer AX1800
    The reason for two routers is because we have extended family staying in an outbuilding (which is hardwired via a single outdoor rated CAT8 130' cable) and they have their own private network (running through my main router and assigned an IP from it), and the second switch is to "split" that CAT8 feed line to their router and my external NetGear ReadyNAS Ultra.
    Thanks for your wisdom!
    • FURRYe38's avatar
      I see you already have a gateway router with the ISP. Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
      Couple of options,
      1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
      2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
      https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
      3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
      https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
      https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
      Try option #2 first...
      Another test to try to see if the XR router handles differently would be to configure the XR router for AP mode whlie you using the ISP gateway as a router with it's wifi disable and test for DNS issues.
      Remove any other 2ndary routers from the mix as well while testing.
      • MrGrumpy's avatar
        MrGrumpy
        Star
        How will I know that this latest cloud update has been installed? The current version is as reported above, XR1000v2-V1.1.0.22_2.1.34.
        I presume the NH will report a different version to the above?
        When I do try it out, I will be configuring the Virgin media box in ‘modem” mode (I.e. no router functions or WiFi) and the NH in router  This will replicate the configuration as from last June to four weeks ago.
  • So six months on, this issue may have returned. Behaviour just as before - internet goes "missing" for a couple of minutes and then comes back. This started three or four days ago. Has there been another cloud update?
    Firmware is xr1000v2 1.1.0.22_2.1.34
    • FURRYe38's avatar
      Does internet LED on top of the router turn RED or AMBER when this happens?
      Possible ISP or DNS issue if this been working all these months then just started happening. Try different custom DNS.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Grab the logs when it next happens and we can take a look. How often is it happening?
