BraveHeart95's avatar
BraveHeart95
Xr500 Constantly rebooting !
hello
i bought Nighthawk XR500 about 9 months ago from newegg the router itself is great , amazing wi-fi range ,qos , geo filter and all other features are great but it is been constantly rebooting for no reason , i tried everything including rollingback on previous updates , change 2.4 and 5 Ghz channels and enable anti buffer bloat but unfortunately nothing seems to work it is keeping to reboot sometimes it doesn't reboot for a week then it would reboot 4 or 5 times in 1 hour
  • Sorry to hear you're having this issue, do you have the router plugged into a power extender by any chance? If so plug it directly into the wall and see if that resolves the issue.
  • FURRYe38's avatar
    BraveHeart95 wrote:
    hello
      • FURRYe38's avatar
        Might reset, manual download v32, factory reset and setup from scratch and see.
