Flexicon's avatar
Flexicon
XR500 DumaOS not loaded yet
A few weeks ago my XR500 router, which has been running flawlessly since I got back in June 2021, stopped running DumaOS. Everytime I try to log in to the router I see the following message:
DumaOS not loaded yet!
Don't worry we will redirect you shortly.
The page then continues to reload infinitely.
The router is currently at version: 2.3.2.130
I have seen many posts on this topic, especially ones specifically for this router model, however none of the solutions presented were helpful in solving the issue for me.
I tried the solutions outlined in the following threads:
This includes:
  • factory resetting the router multiple times (from both the adv_index.htm page as well as using the hardware reset pin in the back of the router)
  • downgrading my router to an older version
  • making sure that no nintendo devices were connected to the router
Hopefully someone might have an idea for something else that I could try because I'm starting to think I have a busted router.
  • You have to wait for 2 minutes after rebooting to ensure it loads correctly and then it should be fine. The next version should almost eliminate this issue as well.
    • Flexicon's avatar
      Flexicon
      Hey, thanks for the quick reply.
      Now do you mean wait 2 minutes after rebooting before trying to access the DumaOS dashboard? Or just wait 2 minutes in general?
      Because if it's the latter then my router has been stuck on "DumaOS not loaded yet!" for like a week now.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Yes once you've rebooted wait 2 minutes before accessing, it can be the accessing part that interrupts the correct loading of DumaOS.
