Xolhid's avatar
Xolhid
Apprentice
Mar 23, 2018
XR500 Factory Reset Itself!!!
I woke up this morning with no wifi and no internet to my wired devices. At first I thought my girlfriend didn't pay the internet bill again. I logged into the router to check some things out. Low and behold, I am greeted by the Initial setup page. All of my settings and preferences were gone and I am forced to start over from scratch! I also noticed that the firmware was updated. I have never in my life seen this before. What gives?
  • Hi Xolhid, the router would have auto upgraded you to the latest version. I imagine that is what caused the factory reset though that shouldn't have happened. Can you continue to monitor the router to see if it factory resets again or if it was just that one off? I'll also look into factory reset after updating automatically.
    • Xolhid's avatar
      Xolhid
      Apprentice
      It won't be hard to keep an eye on it as the internet is unavailable until the setup is complete. It will be obvious if it happens again. I didn't think I needed to use the backup settings feature, but now I guess I have to.
      • Threlnos's avatar
        Threlnos
        Tutor
        Yeah I'm having the same issue as well it's really annoying and I don't understand what the issue is.  This was working just fine for the past week and a half since I got it. I also tried to test something out an a simple reboot and that would trigger this problem as well.
  • ErnestTheGreat's avatar
    ErnestTheGreat
    NETGEAR Employee Retired
    I have 2 XR500s both on latest FW 2.2.1.10 and I am not able to reproduce or observe this issue. What firmware version(s) are you guys seeing this on?
    • theargonaut33's avatar
      theargonaut33
      Guide
      Honestly don't remember.  I'm in the current now.  I was on whatever was before the current firmware.
