alwong26's avatar
alwong26
xr500 geo filter wont load up.
xr500 geo filter wont load up. and neither will my ping heatmap i keep getting the rapp and a uncaught and undefined error message. ive reboot and factor reset and still the samething  can anyone help with this
  • Download the DumaOS app for your mobile from the app store, then access the QoS & Geo-Filter pages and remove any devices that appear there. Then you should be able to access on PC without issue.
    • alwong26's avatar
      alwong26
      i did as you posted and still the samething.
    • alwong26's avatar
      alwong26
      i keep getting these two message and the loading circle
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 2 minutes before accessing and see if it works then please.
