unstable99's avatar
Jan 03, 2022
XR500 Locked up the speed of my computer
Hi GUys,
My network speed is 1000 Mbps,
After i updated the lastest firmware of XR500, there is a problem with this router. My computer 's network speed(download) had been locked on around 10 mbps while the upload speed is alright.  The other devices are ok with the normal speed. I tried to connect the moderm directly with my computer, the speed is ok too. so i can make sure that there is the problem of XR 500. Then i turned off the QOS service and even hard reset the router, the speed locked problem still exsit.
Anyone can give me a hand? Thanks so much.
Kind Regards
Zack
  • FURRYe38's avatar
    Try a factory reset on the XR rotuer and setup from scratch. Be sure to power OFF the modem for 1 minute then back ON as well.
    Whats the brand and model # of the ISP Modem?
    Netgear has set up a community forum specifically for the NightHawk Gaming Router products. Most of the people who watch that forum are more likely to have experience with NH gaming router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
    Thank you.
    • unstable99's avatar
      unstable99
      Tutor
      Hi,
      Thanks for your reply.
      the ISP is china telecom and the brand should be HUAwei, but  i dont think it s the problem of it. because i used my computer to connect the moderm directly ignoring the router, my computer can run full speed of 1000 Mbps(all under lan ). My problem is also under
       lan. Other devices runs well also no matter lan or Wifi. (laptop, tv, speaker. with full speed)
      • michaelkenward's avatar
        michaelkenward
        That is a make, not a  model. Most modems have a label on them.
        FURRYe38 didn't ask for details of the modem on a whim. We have seen a lot of questions come through here and know that the exact details of the modem are important.
        The problem you described is exactly the sort of issue that depends on getting the modem and router correctly configured.
        If you want help, and don't want a dragged out conversation, it would be good if you provided the requested details.
