MorsMessor
Jan 30, 2020Aspirant
Xr500 Randomly Shuts off
It's been doing it a lot sometimes randomly and will happen twice no matter if I shut it off or not. It happens also when I start to stream which it will shut off twice.
- Netduma_AlexNetDuma Partner
What do you mean by "shut off"?
Does the XR500 actually lose power or just drop internet?
When internet drops, are wired devices affected as well as wireless?
- MorsMessorAspirantAll lights shut off/ turn orange tried to force it to happen to take a picture but I factory reset it recently and doesn't do it.
- Netduma-FraserNetDuma PartnerSo since the reset the issue hasn't occurred? Let us know if it happens again please. If it does happen again directly connect to your ISP modem/router and see if that has a connection.
- MorsMessorAspirantIt's like when you reset your router through the Interface on your computer and wifi and all connected devices get disconnected.
- Netduma-FraserNetDuma PartnerWhen you do a factory reset all devices will lose connection so that is normal. Is the router connected to a power extender? If so could you plug it directly into a wall outlet please and see if that helps. Also when the disconnections happen do you see any entries in the log around that time?
