Richtoss
Dec 24, 2020Aspirant
XR500 Return Instructions
So since the RX500 model does not handle the basic functions of staying connected, Can I get the instructions to facilitate a return of the product for a full refund? I believe the instructions were to not take it back to the location of purchase but to go back to the vendor.
Thanks in advance... so tired of dealing with this.
- Netduma-FraserNetDuma PartnerIf you want a refund then you would need to go back to the retailer you purchased from I believe.
- RichtossAspirant
I would accept a working router as well, if you have one of those.
- Netduma-FraserNetDuma PartnerI don't work for Netgear specifically, you'll have to log in here to organize a replacement, you may need to make a ticket first.
https://www.netgear.com/support/contact.aspx
