Retired_Member
Dec 14, 2021XR500 Router Intermittent Disconnections (Please help)
Router is less than a year old, has latest firmware that has been properly installed.
I am not sure why my router disconnects from the internet at random times throughout the day/night. Everything else has no issues except the router; my ISP has not had any issues, my modem works very well, etc. Has anyone else been experiencing this issue? I have tried every logical solution and am curious if someone can help, thanks.
Also: yes, I have plugged it into a different outlet by itself and that has not done anything. I might replace the outlet if no one has any other ideas. The cables are all correct and are working properly.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapter for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Also power OFF the ISP modem for 1 minute then back On. Complete the setup wizard.
- Retired_Member
The firmware is 2.3.2.130.
The modem is a Netgear CM1000; the modem works very well and I have had no issues with it. When connecting my computer directly to the modem, I experience no disconnects and all of the lights are illuminated green.
The router has been factory reset from within the DumaOS app. This issue has occured in the prior 3 beta firmware updates (I have dealth with this for a few months).
I did reboot both the modem and router after factory resetting for the firmware update (I've done this 3 times now. The issue remains the exact same). I also periodically reboot the modem and router by shutting off and pulling the cord for a minute.
Is there anything else I should try? I really don't know what to do.
- Netduma-FraserNetDuma PartnerIn addition to the above suggestions, changing the DHCP pool to start at a higher value e.g. 50 instead of 2 and then giving devices reserved IPs between .2 - .49 can help resolve the issue.
- Retired_Member
How do I do that? Also, how would that help if you don't mind me asking? Thanks.
- Retired_Member
Done. Hopefully this resolves the issue. If not, do you think downgrading the firmware will resolve this? I only started getting this issue when I began using beta firmware. Also, when do you think netgear will have this issue resolved?
- Netduma-FraserNetDuma PartnerUnlikely as it was present on that version also, couldn't say exactly, hopefully for the next version
