Risqaye
Oct 05, 2021Guide
XR500 Slow ethernet fast wifi
I recently purchased a Nighthawk XR500 router. When connected to my modem I'm only getting about 20mb download and like 1 upload. My wifi gets 240mb down and 20 up. I've replaced my ethernet cable and tried all four ports. I've also disabled QoS and enabled and doesn't seem to help. I've factory reset and rebooted and even left off for hours and still nothing. When connected to the modem my pc gets 300+down and 20+ up. V2.3.2.114 is my firmware version. I'm out of ideas so any help would be appreciated. My modem is a Nighthawk CM2000 and my provider is Spectrum just to help with hardware and ISP information.
Model: XR500|Nighthawk Pro Gaming Router
- Netduma-FraserNetDuma PartnerCould you provide a screenshot as an attachment here of your Device Manager table view please?
- RisqayeGuide
- Netduma-LiamNetDuma Partner
Everything looks OK there, could you confirm if all devices are having this problem or is it just your PC?
How did you disable QoS? I'd suggest doing so by clicking the three-line menu in Congestion Control and tick the box 'Disable QoS'.
Another thing to check, if you go to the three-line menu in Bandwidth Allocation, is Share Excess ticked?
