Xr500
Mar 15, 2019Apprentice
XR500 V2.3.2.40 Two Serious Bug
Two Serious bug Reasons for appearance:
Long-term uninterrupted Download
Two Serious bug Reasons for probability:
Each Long-term uninterrupted Download
Two Serious bug Reasons for Interim solutions:
Restart using Shutdown key
First Serious bug:
Anti-Bufferbloat When operating all settings.
Error prompt:RPC error 'ERROR_NOENT': Rule not found in chain
The second Serious bug:
Internet Orange Lighting.
5Ghz and 2.4Ghz White Lighting.
Eth1 White Lighting.
Mobile phones and Computers No network.The same is true of waiting a long time.
And don't go in and Manage Pages. www.routerlogin.com Blank space nothing shows.
Must be forced to restart using Shutdown key.
:smileysad: It has happened many times. I need help.
Has a factory reset been performed after updating to v40 then setup from scratch?
How are you determining these issues?
What does long term uninterrupted download mean? Are you having problems with downloads? Would need more details on this?
You might revert to v32 and see if anything is different.
Restart using Shutdown keyFirst Serious bug:
Error prompt:RPC error 'ERROR_NOENT': Rule not found in chainThe second Serious bug:
Must be forced to restart using Shutdown key.:smileysad: It has happened many times. I need help.
- Xr500Apprentice
Thank you very much for your timely reply.
- I don't know my ISP modem.Connection mode PPPoE.
- Updating a version will restore factory settings.
- WINDOWS 7 Computer Performs Download Task. The download software is BitComet. Download for about 20 hours. XR500 Problems arise.
- Previous versions did not have this problem.previous versions contained security vulnerabilities.
Would need to find out modem model information.
updating FW does NOT restore factory resetings.
What prior versions of FW worked for you?
- Xr500Apprentice
Three months have passed.
My problem still exists.
i have tried many times Reinstall the FW .
factory reset been performed after updating to v40 setup.
- Netduma_AlexNetDuma Partner
Are we talking about the first problem (anti-bufferbloat) or the second problem (can't access interface)?
