kentgiard's avatar
Apr 24, 2022
XR700 Bricked!
All of a sudden, my router admin page started to display this (on firmware v1.0.1.48)
Thinking a factory reset would solve this, I went through the steps and was able to get through the wizard but once everything was set up the same screen keeps popping up. This means I am unable to configure any settings past the initial wizard. This occurs regardless of which browser I use (chrome, edge, safari, etc.)
My next step was to TFTP and try old firmware, but that won't even flash. I even tried XR700-V1.0.1.34_Duaos3.0_6.img and that doesn't work. In all cases, I can get the file to transfer (the bytes transferred matches the file size) but the router won't boot. I can flash the router to 1.0.1.48 again, but the R-App error shows up. My router is now unusable!
Does anyone know a fix for this?
  • Unfortunately I can't see the image you've pasted as it's not been moderated yet.
    Could you please instead try attaching it rather than pasting it in?
    • kentgiard's avatar
      kentgiard
      Tutor
      It's just an image of the message "This R-App is not loaded yet, please try again in a minute." (now attached)
      Hitting okay refreshes the page and displays the same message.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        When this error occurs, it is almost always resolved by a reboot, so reboot then wait 2 minutes before trying to access and see if it loads then
