buck84
Dec 06, 2021Tutor
XR700 keep getting connection issues DHCP?
I keep getting "connected no ip address" or "Unable to connect to the internet"
We have maybe 30 devices connected and it is happening intermittently
The firmware is V1.0.1.46
I have an extender X700
Getting DHCP lease change every 20 - 30 minutes
From the log
[DumaOS] Marking device that is marked 10.0.0.16 52 78., Monday, December 06, 2021 10:55:14
[DumaOS] Marking device that is marked 10.0.0.9 72 52., Monday, December 06, 2021 10:55:07
[DumaOS] Marking device that is marked 10.0.0.16 52 78., Monday, December 06, 2021 10:54:28
[DumaOS] Marking device that is marked 10.0.0.9 72 52., Monday, December 06, 2021 10:54:21
[DumaOS] Marking device that is marked 10.0.0.9 72 52., Monday, December 06, 2021 10:53:36
[DumaOS] Marking device that is marked 10.0.0.16 52 78., Monday, December 06, 2021 10:53:25
[DumaOS] Marking device that is marked 10.0.0.9 72 52., Monday, December 06, 2021 10:52:52 [DHCP IP: 10.0.0.42][Device Name: ] to MAC address XXXXXXX, Monday, December 06, 2021 10:52:35
[DumaOS] DHCP lease change., Monday, December 06, 2021 10:52:35
[DumaOS] DHCP new event., Monday, December 06, 2021 10:52:35 [DHCP IP: 10.0.0.42][Device Name: ] to MAC address 1a:cf:56:c3:83:d9, Monday, December 06, 2021 10:52:34
[DumaOS] DHCP lease change., Monday, December 06, 2021 10:52:34
Looks like you have a router in front of the XR router already.
Have you setup some IP address reservations for your devices ON the router?
X700 is not a valid model for a extender. EX#### or EAX##
- buck84Tutor
The modem is an Arris NVG589 from 2015
The WAP is Cisco VEN501-AT
Both WAP and the netgear XR700 are attached to the Arris with CAT5e cable
The Netgear has been attached for about a year and these issues started maybe 60 days ago.
Thanks for the quick reply
- Netduma-LiamNetDuma Partner
Are any devices connected directly to the XR700? Are they also experiencing this issue or is it only devices connected to the AP?
Are you able to see all the devices connected to the AP in device manager, or is it just the AP that you can see?
Do these devices show as going between online and offline in Device Manager, or do they show as being consistently offline?
If you reserve IP addresses for each individual device that's having this issue, does the problem stop?
