nuubje006's avatar
Mar 26, 2020
XRM570 Nighthawk Pro Gaming completely disconnects from the network
Hello,
Since 2 weeks now I have been having some minor issues (lag). Already called my provider and they did not see any issues. Then I started having disconnects for extended periods of time.
I resetted the XRM and it worked again, so this seems to be the issue.
Didn't have any issues for weeks, but now it starts to disconnect again and I can't get it to connect again. The leds are blinking etc. so it does seem fine from the outside.
I am not even able to connect to the router from any of my devices, so I can't even see the firmware.
If I bypass the router, my network works just fine, but I need it to have several connections as I am working from home at the moment because of the recent crisis and I am at the end of my rope here. Please assist.
Will provide with all the required info as much as I can.
  • Could you clarify a little if possible please - When it disconnects does it occur on all devices including those wired and those connected wirelessly? If it is just wireless devices, remove the extender and connect them direct to the router wifi do they continue to disconnect? When you're trying to access the interface are all those devices you've tried connected to the extender or are some connected directly?
    • mastermonopoly's avatar
      mastermonopoly
      I am running into the same issue recently, so I can provide the details I am seeing on my end.
      When the disconnect issue happens, all devices disconnect (both ethernet and WiFi).
      The lights will stay on as if nothing happened, but no devices can connect.
      After connecting directly to the router via a wired Ethernet connection, I cannot connect to the router in any way (router IP is not found).
      For me currently, it occurs 2-3 times a day, typically during high load times. It allows devices to reconnect after about 2-3 minutes.
      Firmware is up to date. Running R7000 AC1900 WiFi Router.
      Logs from around the time of the failure are below:
      [Admin login] from source 192.168.1.16, Thursday, Mar 26,2020 11:25:30
      [Admin login] from source 192.168.1.16, Thursday, Mar 26,2020 11:25:13
      [DHCP IP: (192.168.1.16)] to MAC address A0:51:0B:6E:B6:FD, Thursday, Mar 26,2020 11:24:43
      [DHCP IP: (192.168.1.15)] to MAC address 38:30:F9:17:56:7C, Thursday, Mar 26,2020 11:24:05
      [DHCP IP: (192.168.1.14)] to MAC address 70:1C:E7:8C:05:AA, Thursday, Mar 26,2020 11:23:52
      [DHCP IP: (192.168.1.13)] to MAC address 9C:30:5B:BD:18:ED, Thursday, Mar 26,2020 11:23:22
      [DHCP IP: (192.168.1.11)] to MAC address E8:D0:FC:ED:C4:EB, Thursday, Mar 26,2020 11:23:20
      [DHCP IP: (192.168.1.5)] to MAC address D0:13:FD:6F:BC:43, Thursday, Mar 26,2020 11:23:14
      [DHCP IP: (192.168.1.7)] to MAC address CC:3D:82:90:C5:18, Thursday, Mar 26,2020 11:22:55
      [Time synchronized with NTP server] Thursday, Mar 26,2020 11:22:50
      [Internet connected] IP address: 192.168.0.91, Thursday, Mar 26,2020 11:22:49
      [Internet disconnected] Thursday, Mar 26,2020 11:22:48
      [USB device attached] The USB storage device TOSHIBA External USB 3.0 (Thomas Backup Drive) is at Thursday, Mar 26,2020 11:22:48
      [DHCP IP: (192.168.1.10)] to MAC address 0C:72:D9:42:DF:6F, Thursday, Mar 26,2020 11:22:46
      [DHCP IP: (192.168.1.9)] to MAC address F0:18:98:87:92:FB, Thursday, Mar 26,2020 11:22:45
      [DHCP IP: (192.168.1.8)] to MAC address D8:49:2F:B7:82:42, Thursday, Mar 26,2020 11:22:45
      [DHCP IP: (192.168.1.6)] to MAC address F0:5C:77:1C:96:CF, Thursday, Mar 26,2020 11:22:44
      [DHCP IP: (192.168.1.8)] to MAC address D8:49:2F:B7:82:42, Thursday, Mar 26,2020 11:22:44
      [DHCP IP: (192.168.1.4)] to MAC address 24:5A:B5:AB:08:19, Thursday, Mar 26,2020 11:22:44
      [DHCP IP: (192.168.1.4)] to MAC address 24:5A:B5:AB:08:19, Thursday, Mar 26,2020 11:22:42
      [DHCP IP: (192.168.1.12)] to MAC address E8:D8:19:E6:8A:BD, Thursday, Mar 26,2020 11:22:36
      [DHCP IP: (192.168.1.3)] to MAC address 00:9D:6B:28:6E:B6, Thursday, Mar 26,2020 11:22:29
      [DHCP IP: (192.168.1.2)] to MAC address D4:F5:47:29:4E:BC, Thursday, Mar 26,2020 11:22:27
      [Initialized, firmware version: V1.0.9.88] Thursday, Mar 26,2020 11:22:26
    • nuubje006's avatar
      nuubje006
      Star
      Hello, thank you for the quick responds.
      I am having the the same problem as @mastermonopoly discribed.
      All ethernet devices and wifi devices are disconnected and the router ip is not found so I can't go into to router. I wanted to add the log file but it only goes back to Thursday, March 26, 2020 18:05:44 and the issue was before that.
      I was downloading 2 games and a driver package when the disconnects happened and also 3 other devices on the network. My work laptop, phone and a raspberry pi.
      I had the issue before and posted the log on a forum but I can't seem to find it anywere. There were some DOS attack errors in it.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        When the issue occurs could you run command prompt and type ipconfig then press enter please and post the results here. Also do a ping to the router IP and post it here.
